1 - 14 of 14 Posts
I have a B&G kit and I cant see how the 3.5 inch down pipe is going to get in there with the passenger side header installed. I can get the downpipe in with the header pulled forward but how do I secure the header with the downpipe in there.
I already cut the swap bar mount and I have to bend the frame rail pinch weld, which I was hoping I wouldn't have to but the turbo flange sits on the rail.
I have AC so it is really tight in there.
Thanks,
Eric
Un bolt the engine mount from k member and jack up the motor by the oil pan but make sure you use a 2 by 4 so u dont dent your oil pan shud fit no problem
The passenger side mount or both of them?
Eric
You can just do the passenger but I do both to rock the motor to make it easy
Radimm, yes that is how I got it to fit. I have a really old kit like revision 1 and when I called and spoke to Brian he said there might be a chance it was all hand made and would need the cover removed and AC lines and accumulator bent out of the way which it did but I got it in there so now I can move ahead with the completion of it.
Can I use stock plug wires or should I get a set of make your own and run them under the headers?
Im glad someone posted this. Ive had my B&G kit for 3 years and i still have no idea how anyone with a 3.5" downpipe installed theres with there headers installed.
Ive had my intake and valve covers off and theres still no way it was going in.
First few times i would install the down pipe first then have a friend hold it up while struggling to bolt in the header below it. This method usually ends up with leaks if using straight silicone, which becomes extremely frustrating.
I now install my headers and turbo on the engine stand and lower the motor into the bay and install the downpipe just before the motor makes contact.
The urethane motor mounts are a must have for this kit. What I did was remove valve cover, unbolt the accumulator and push it to the passenger side door and then the pipe slid in. Still had to turn it a bit but the pipe was wrapped to.
Glad I could help some others out as well.
Thanks,
Eric
Discussion Starter #12
Coilz, do you use an exhaust gasket? I'm going to use silicone but if it won't seal I don't want to mess with that. Would rather only do this once.
Just finished installing one for my brother. No issues with the headers on. Just have to work it around to find the right angle.
Discussion Starter #14
I know the newer kits have different bends for the DP. I picked up my hotside in 06 so it was a revision 1 setup and there have been quite a few changes which aide in install. I am glad I got it in though, or at least got it solved to get it installed. I also have full AC to work around.
1 - 14 of 14 Posts
