This is on my 94 Cobra. Ive got a MSD 6AL. Also have a Autometer 5 inch tach with shiftlite. I want to take the original shiftlite off and install the ninosport HUD shiftlite in. How would i do this.
Here is his website for the shiftlite. He doesnt tell you how to hook it up unless you have a rpm module. Any help would be apprecaited. Thanks
I'm not positive but does'nt your current shift light have two wires going into it? one is a ground and the other is a trigger.... right? well then those two wires should be extended to hook up to the new shiftlite.
I will check it out when i get the tach(still in mail) But i want to be sure of hwo to do this when i get it so when im doing the install i wont have to goto the board every 5 min. :) All help is appreciated. Thanks.
You;ll like Nino's HUD shift light. I have one, hooked up to a MSD RPM module, and like it a lot. The shift light wires on the tach will work, just extend them to the HUD light.
