Anyone use a RPM Airgap carb intake under stock hood 1995 Mustang ? If so what air filter you use - thanks
I'm considering going to carb. Did you pull the engine harness only and leave the ECU and CCRM in place?
Wiring Harness
...going to remove everything and install a switch panel in place of the radio & storage bin for ignition, crank, fuel pump, electric fan, and electric water pump...MSD box for spark & one wire 3G alternator is all in engine compartment...
Will you run the fan full time or is this a track car only?
