1 - 16 of 16 Posts
anyone have pictures of turbo systems they built at home? maybe using shorties flipped forward?
buddie of mine wants to turbo may car this winter. he can build the piping so im trying to get some ideas of how id like to do it...
Id start with some FRPP headers in stainless if I were you, just flip them and use that as your starting point
I ended up using accufabs mid lengths for my build, but I required a 3" bolt pattern for my heads. Other wise I would have used the FRPP stuff.
anyone ever used a stock cummins turbo?
I used a hot side from BG and made my own cold side. A GOOD bandsaw is a must. I didn't have a welder so I marked and taped (blue painters tape) all my joints and trucked them to a buddy. Having a welder or simply the means to just tack weld would have been so much better.
From my little experience it would be no problem building a kit from scratch.
What about a cut off saw, for the diy'er?
work alright or is a bandsaw a must?
are we talking a little handheld or a full size stand up bandsaw?
thanx
Hit the reply button to soon.
... I did rotate the wg and add a downpipe to it to get the exhaust out from around the motor / turbo.
1 - 16 of 16 Posts
