Moderator
The top hole left via heater whats the right way to plug this is it also for water drain? The top one not the firwall ones i welded them.
It's not specifically intended to drain water. there are holes in the corners for that. You can weld it up no problem. I personally riveted a peice of Al. over it, and sealed it. Just incase I ever want to put heat back in the car.
