1 - 10 of 10 Posts
I have been battling some IAT issues which is preventing me from turning the boost and timing up on my car. I had a smaller intercooler, so I swapped it out for a new 4" Mishimoto large core intercooler. Temps with previous intercooler were 160-170* right before the intake at the top of the 1/4 mile with only 16# boost and 12* timing. After swapping out the intercooler, the temps were down a little bit to 140*-150*, not as much as I was hoping. I had a buddy ride along with me to video the intercooler temps. I installed a gauge that reads pre and post intercooler temps. I was surprised to find that the pre intercooler temps were over 300*, so the intercooler is definitely working! Any idea why the charged air temps are getting so hot? Anyone else had this issue? This is a built 4.6 2V with FF CG fab headers, precision 76/75 CEA turbo. Thanks for any help.
Sounds comparable to the temps I see just before the TB. Turbos get very hot due to the exhaust housing and transfer that heat to the incoming air.
ks
  • Like
Reactions: TomR
Couple of guys I've talked to said they usually see around 110, so I was hoping to hear what a few other people were seeing and if this was out of the ordinary. I have mine set to start pulling timing at 150* I do have a meth kit I can still install, I just wanted to use it as more of a safety net and not a solution. I'm pretty close to being in the 8's now, but don't want to turn it up until I can get this under control.
Really? 110* with an Air-to-Air IC?
I'm on street gas and my system doesn't pull timing since I run 100% meth inj. I do monitor the KR with a Safeguard system tho.
ks
  • Like
Reactions: TomR
I get right around 100* IAT at 20 psi at the big end, (twin screw not turbo) but then again I run an air/water set up that allows me to run ice water and that helps a lot. Over 300* before I/C is not uncommon at all.
That's good to know the mishimoto doesn't cut it at that level because I was considering one myself.
Have you done any heat treatment under the hood (wrap, turbo blanket, etc)?
Your temperatures do not sound out of line for an air-to-air at fairly high power, assuming the ambient air is around 85F or so. I have an air-water-air system and I'm about 50 above ambient air at 22-25 psi boost at the end.
It will get tougher fast to get lower than 50F above ambient without ice water if you are making any power. I don't believe anyone could do 110 with an air-to-air in 85F ambient unless the power was low and the intercooler pretty large.
why not add water injection...
Next car will have air/water setup, I'm not going to change much more on this car as it has already gone way over the original plan. lol I thought 300 seemed high, but I'm glad to hear that this is not uncommon, thank you for the info!
Headers and turbo are ceramic coated. I have a turbo blanket, but need to get a different one. The one I bought is too bulky and hits my water pump so I have not been running one.
Your temperatures do not sound out of line for an air-to-air at fairly high power, assuming the ambient air is around 85F or so. I have an air-water-air system and I'm about 50 above ambient air at 22-25 psi boost at the end. It will get tougher fast to get lower than 50F above ambient without ice water if you are making any power. I don't believe anyone could do 110 with an air-to-air in 85F ambient unless the power was low and the intercooler pretty large.
Ambient air was about 70-75 with temps reaching 140 on the new intercooler. Old intercooler temps were 160-170 with 50 degree ambient air temps, so the new intercooler is working better. The other person did have a good bit less horsepower, so that makes sense. Thank you for the help!
I am going to get my meth system hooked up now, just haven't had a chance with trying to chase all these other bugs.
1 - 10 of 10 Posts
