WHATS A GOOD COMANY TO GET A GOOD CHEAP HOGH PORT TURBO HEADER FROM OR A GOOD USED USED SET OF WOULD BE FINE IM NOT LOOKIN TO SPEND 1000$ FOR A HEADER
Jersey True Street Guy
Most of the kits out there are for standard port configuration and will not work with high ports. There are 3 issues when you try to do that:
1. the top of the header flange hits valve cover rail
2. the cross over pipe isn't wide enough
3. the turbo may hit the hood
B&G has done many of these hotsides and is able to do it because they are fabbed on a jig which they switch cylinder heads when making the header.
I would suspect that C&G Fabrication can do it also.
You could troll for used kits, there may be some out there.
i seen a site called pony down im just lookin for headers n i can build my own hot side
Do a search, seems like they are unresponsive lately. Most will give you whatever you ask for. If it was me I would at least get headers and cross over but it is your call.
