1 - 9 of 9 Posts
Looking at putting a single turbo on my soon to be new 89 with 331. I want to keep tailpipes out the back for asthetic reasons. Is the 3" downpipe to the y then into 2 2.5" tails enough or do I need to go to 3" tails??
Depending on the turbo and power goal. Is it a stock block 331? If so then the 3"dp and 2.5 cat back is enough.
What is the limit on a 2.5 catback? Seems like 2.5 would be plenty considering you only have a 3" down pipe.
stock block, so im thinks ng 2.5" is enough until i can upgrade block and then turbo and then injectors and maf and then exhaust lol
Im running a Magnaflow catback with a 3" downpipe. You should be good.
hows the sound with tails and turbo?
Stockish at idle untill I hit the loud pedal!
I have several vids on streefire.net if you just type in "jturmanator"
hmmm, might just get one of them vrs 3" tailpipes for now and add 3" mufflers later
1 - 9 of 9 Posts
