The is car is dead nut 3 pounds of boost on dyno then graph leves and all the way to let off. This on a turbosmart pro gate 50mm wastegate with 7 psi spring. I don't hear any . I would think 4psi leak would be heard. I have verified the spring in wastegate.
Formerly eades5.0
Do a visual on the diaphram and a vaccum test on the gate
I also had a similar issue and my valve was sticking, 7yr old gate and TiAL replaced valve/seat no charge.
