I have eibach drag launch kit. (tokico drag struts in front no swaybar)
rear steeda weight jacker lower control arms, steeda double adj. uppers. I am running bushings. (rear shocks tokico illumina 5 way adj.)
car is 93 cobra full weight, battery is on right rear. nitrous is on left rear. still run quad shocks.
I run skinny's up front
rear are 15x8 w/ 255 60 15 mickey thompson drag radials.
pinion angle is adj correctly.
avg 60 ft times are 1.9.
Please give me advise on what is wrong?
car is stick shift, leave 4000k on motor, once car is in motion I spray 150.
Discussion Starter #2
help
no input from anyone?
if i were you i would go lakewood 90/10's front and 70/30's or strange 10 ways in the rear it should be cutting at least 1.7 60'
I wouldnt change shocks, i hear very good things about the Tokico 5-way drags.
I have a set as well, but car isnt up yet so no personal feedback.
Even Al P told me i made a great chioce in shock.
What gears? Does it seem to spin, or bog, or what?
Tried any diff RPM?
Hope someone like Kevin will chime in with some ideas...
put it on the rev limiter and dump the clutch....its awful difficult to launch properly why your looking at your tach....especially with a manual.
