21 - 30 of 30 Posts
Sounds good! Connectors and pins for expansion pigtails are here, just waiting on labeled wire to get here.
Everything is here to make the expansion pigtails now btw. It's not on the site as well so the expansion pigtails are ready to go.
Discussion Starter #23
back from the dead, just an update. I went with ms3pro gen1 and it has been great. a bit of a learning curve that i still havent mastered but its been good and the support ive received has been very very helpful.
I like that the Stinger uses the Ford Harness. I also like that it uses a stock size box that fits in the stock location. It will do everything I need for at least half the price of the high dollar units.
I'm no racer, so this stuff isn't taking every last cent from my wallet.. It can do a lot for the money. Where do these people get all this money anyhow?? This hotrod stuff ain't cheap no matter what.
I ask myself the same question.
I have the non plug and play megasquirt and it wasn't really that difficult to get going, I definitely don't have anywhere near 100s of hours into it.
Formerly LSNotch
Is the micro squirt from efi source pnp to the factory harness? Or do you have to strip/create harness like you can do with the ls?
Definitely plug n play. Word of caution, the EFISource kit comes with a base “tune” that really needs attention. I thought it was good enough to start with that as a base and then realized I needed to ensure everything was reviewed and adjusted.
21 - 30 of 30 Posts
