Well getting ready to finish the turbo setup, now I need to get my tire setup for drag racing together here is the setup right now..
93 Cobra
Stock/Cobra long block (1.7rr, porter lower and upper,75mm TB)
On3 Hot Parts and Cold Side (masterpower t70, tial 41mm wastegate,tial 50mm bov)
42lb injectors, c&l maf, profesional products fuel rails, aeromotive fuel pressure regulator, Walbro 340lph fuel pump
The car still have the stock T5 and running some big and skinnies with MH 26" ET streets
also chaning the gears to 3.27 so I was wondering If I have to change to 28's stiff walls if so which would you recommend...thanks
are you running the 1/4 or the 1/8 ?I just picked up a set of MT ET slicks 26x8 and they hook great with a 3650 and 3:27 gear.
