1 - 14 of 14 Posts
HEY ALL, Newbee to turbos. Just paid for and waiting for new 427 shortblock from fordstrokers. Having comp.ratio set @9.5:1. I have afr 205 heads, don't remember what spring preasure,not original springs.tfs box r intake w/ wilson90mm. tb, 60lb injectors.
I want to turbo it this winter but have no clue as to who makes a good quality unit and who to stay away from, what size, I am prety sure I will have to have another cam as the current one is a nitrous cam.
please help educate me so I can make the right choice
thanks; John
ive been looking at comp billet turbos lately. they have a wide selection of sizes and most have a race ported cover with a 5.5" compressor inlet. Their 88mm has a 6" inlet. People have been trying them out alot on the supra forums
Jersey True Street Guy
That is a big cube motor with a significant amount of compression. I think you are at least in 88mm territory, maybe something like a gt5588. A twin turbo kit could work also with ~62's or so.
Be careful not to put too small a turbo, it doesn't end well.
What year car is it going into?
I would be interested to see if twin turbos are worse then a single for underhood temps.
How fast and what kind of power are you after?
Street car?
would like it to go 10.0s w/ minimal boost at first due to roll cage restrictions. Hopingto get it to skinny kid next year for the rest of the cage(currently a 6pt). But in the end I would like to make 1100- 1200 at the crank and pull a low 9.
It is going into a 94 cobra that is currently 3105lbs. w/ me in it.
Twins are one of my thoughts also, Would i be correct in assuming that two smaller turbos would spool up a little faster? Under hood temp. was one of my concerns. I still want to be able to drive the car localy within a 25mi radious without worrying about temp.
I should also mention that I use big stuff 3 so I do have the meens to control the boost already.
In theory, they really shouldn't. You are still producing the same volume of exhaust and trying to make the turbos move the same amount of air. Spool time is really based on properly sized turbos on your motor.
You are putting together a monster, in my opinion you really don't want super fast spool time if you drive on the street. My experience on my car is that it is easier to drive on the street with a larger turbo and slightly slower spool. With a smaller turbo it just incinerated the tires. At the track, you will build boost with a transbrake and you can work through a moderate level of street driving lag.
Regarding the temp, make sure you plan out your cooling system carefully. I would suggest remote mounted trans cooler with a fan to keep it from blocking the radiator. Use the biggest electric fan you can find and a good radiator. I also run the mezier street electric pump with idler to allow cooling the motor down after stopping. It is always on KOER, then there is an override switch for when the key is off.
The more planning you do the better....too many of us have changed too many things trying to figure these things out :crying:
I could tell some stories about that but let's just say I understand and do not plan to start to make the transition to turbo untill I am compleatly satisfied that this is the right way to go and that I have the right package togeather.
As I think about this I May need to change converters also.I have a good rad. and trans. cooler I can add a fan to.
so w/ that in mind I would need to get;88mm turbo w/ what size intercooler? also I have no clue as to what brand or who makes a system to fit a 94, or a reputible dealer.
T6 88mm might be too small. You need it to be bigger because of your cubes. Your injectors won't cut it at 60lbs and your horsepower goals. Your trans probably won't survive too long with that much power. At last, you will need to change your rearend gears. Like MCJ50 said, you are going to instantly fry the tires with the 88mm. You are probably better off dropping the car off and have a custom turbo kit made to your car. Forget about 9's, you will be in the 8's easy with that cube and turbo. You will need a chute on top of your cage.
Discussion Starter #12
I was thinking 3:55s for the rear. am looking into a lentec trans. wasen'sure about injectors,And had not even thought about the shute.
I just got off the phone w/reed @ works. He said I could make it w/ a smaller turbo but would be a little smoother on the street street.
as far as a custom kit,If it comes to that I will probably check w/ donny walsh as i am aquainted w/ him and currently does my tunning anyways.
Is the block stock or aftermarket. If it were my I would put a 91mm on there and adjust boost as nessary for type of block. This turbo will still spool on the street and make crazy power if needed.
Discussion Starter #14
This is a dart shp block w/ scat 4340 crank and h-beam rods' diamond 36cc dish pistons.really only need it to run low 9s. I truly think that at that it will be all that I care to saddle up.HMMMMM seems like dejavu. just want to put it to that anyone who knows the car would chuckle at the question, IS IT FAST? I don,t intend to compeat at the track on a regular bassis but maybee once a month. I am one of those guys that want way to much power than needed for the street. I have been told It has something to do w/ little guy syndrome.
1 - 14 of 14 Posts
