Greetings fellas,
I am looking at adding boost to keep up with my brothers Twin Turbo 2016 GT.
My setup is the following:
363 SBF
Custom Cam from FTI
TFS 190 11r street port
TFS Box R manifold
90mm throttle body
47lb injectors
Long tubes to 3" high flow cats
Borla straight through mufflers
Moates Quarter Horse tuner
Right now it spins to 7k RPM as a motor car. Don't know HP as it's never been on a dyno, but it pulls pretty good.
The car weighs 3380 with a full tank of fuel, so with me as the driver, the car weighs 3570. She's a pig.
I have stock rails and lines, so I know I will need a greater supply of fuel-including injectors.
It's got full accessories minus the smog pump and I want it to stay that way.
Houston is hot. Not getting rid of my AC.
I want an intercooled setup but there is basically only ONE. The procharger setup.
The problems I have are:
I want to make sure the size of the blower is enough to fill the extra cubes of the 363
I have a fox throttle body conversion and AFM power pipe.
Does anyone have recommendations on a vendor that can piece something like this together?
Thanks in advance!
