1 - 9 of 9 Posts
I've been working on trimming my dash wiring harness for my 2000 and I can't identify what these connectors go to. They are both around where the turn signal relay separates from the main harness. Thanks for the help!
Are they not id’d on your wiring diagrams?
No, unfortunately they're not. The 3-pin plug looks just like an airbag plug, but it's black instead of the typical brown.
I will look up later
2000 gt?
Sorry, my earlier response didn't post for some reason. It's for a 2000 v6 but it should be the same as the gt for those connectors. The three pin connector is the same as the brown airbag connector but it's black.
I could not find the component pages
what wiring diagram are you using?
do you know the wire terminations?
I'm using the HELM diagram book. I found that the 3-pin connector is for the shift lock actuator, the other I ended up removing because the car still started and functioned properly without it, it's the grey one in these pictures:
http://i327.photobucket.com/albums/k457/jmccormick06/99-04 dash removal/5618A441-0B11-46DC-8B5B-9EBDAEAA9BEA-7146-00000239EF996EF7_zpsf84e7621.jpg
http://i327.photobucket.com/albums/k457/jmccormick06/99-04 dash removal/04F5249B-2DB5-441C-8258-C1345F83A203-7146-00000239CDED22B5_zps7a745c7e.jpg
I think it may have gone to the steering wheel controls?
1 - 9 of 9 Posts
