My '89 is a daily driver. For some reason I don't get alot of heat when its cranked up.
I have a remote car starter and in the AM it runs for 15 mins or so with the heat on, when I get in it is a little better than outside but not warm, on real cold days it doesn't get comfortable until 10 mins of driving after 10 mins of idle.
I have the stock radiator and even have underdrive pulleys. Is there a heater control valve that might not be opening all the way or does coolant flow thru the core all the time???
My '92 stang was doing that about 2 yrs. ago and i couldn't get much heat and then had a small hole in one of my heater hoses on the back of engine where it hooks to the heater core. When I changed the hose it was the one that had the small restrictor in it and the restrictor was clogged. I replaced it with a new hose from ford that had a restrictor in it (so as not to blow out the heater core) and had instant heat!!!:D
Hope this helps......
My car used to have heat so hot you couldn't stand it... and now it is luke warm at best. My thermostat broke last year and I couldn't find another 190* thermostat so I stuck in a stocker... BOY WAS THAT A MISTAKE!!! Now my heat barely works.. Next year once the weather starts cooling down I am going to replace that sucker before winter hits.
DOWN WITH STOCK THERMOSTATS!!!
Stock thermostats are 195', you probably put it in backwards. Install it with spring side in and your problems will go away.
Vernon
