1 - 1 of 1 Posts
Headswap Guys,
I have LT's for my swap. I was wondering(for those with the same), when you go to put your new heads back on, can you bolt the pass. side header to the head and then slide it down and attach? Can the same be said for the driver side? Mind you, I will be jacking the motor up anyways for additional clearance. I do/will have a helper even if it's me holding the head and header and getting a bolt started. Thanks, R
1 - 1 of 1 Posts
