1 - 20 of 33 Posts
331 stroker shortblock includes a cast steel crank,h-beam rods,mahle forged pistons,comp custom nitrous camshaft,water pump,canton oilpan all for 2,500.00 firm(will need bearings)
331 stroker long block includes Edelbrock victor jr intake and heads, ford racing valve covers ,msd distributer and wires,a cast steel crank ,I-beam rods,mahle forged pistons,comp custom nitrous camshaft, water pump, oil pan all for 4,500.00 Firm
331 stroker long block includes Edelbrock performer heads,ford racing valve covers ,msd distributer and wires, a cast steel crank ,I-beam rods,mahle forged pistons, comp cams flat tappet camshaft, water pump, oil pan all for 4,000.00 Firm
306 bottom end with aftermarket pistons,camshaft, lifters and a double roller timing chain for sale,I dont know the cam specs but is a hydraulic roller,motor comes with solid mounts,157 tooth flywheel,balancer, water pump,timing cover and oilpan for 1,500.00 firm
(1) 5.0 ho longblock with upper and lower intake for 850.00 each
(1) 5.0 ho longblock freshened ready to go for 900.00
(1) 5.0 ho longblock with 93,000 actual miles in great condition for 1,000.00
(2) 302 standard bore 5.0 xxx roller blocks for 300.00 each
(1) 302 standard bore shortblock that needs rebuilding for 300.00
(1) 302 standard bore mid 70s block for 150.00
Jomar stud girdles for tfs and canfield heads like new for 100.00
trickflow 6.500" .080 pushrods in good condition for 90.00
trickflow 6.550" .080 pushrods in good condition for 90.00
(2) sets trickflow 6.700" .080 pushrods in good condition for 90.00 a set
5/16 x 7.000 .083 pushrods in good condition for 90.00
trickflow 7.00" .080 pushrods in good condition for 90.00
7937 competition cams 7.050 .080 pushrods in good condition for 120.00
trickflow 7.800" .080 pushrods in good condition for 90.00
comp cams 7.900" pushrods used for 90.00
professional products neutral balance balancer for ford motor in good condition for 125.00
professional products 80007 balancer new in the box for 85.00
high performance 50 oz balancer like new for 150.00
(1) sets of Arp head bolts used for 351 70.00
1 set of arp studs brand new in the box part #154-4005 for 130.00
BBk part #1559 pulleys like new for 100.00
(3) race crank pulleys used for 35.00 each
(used)set of 20 over 345 cu. kieth black silverlite pistons makes 345 cubes
for 150.00 or make an offer
ford racing A351 1.6 pedastal mount rockers part#m-6564 like new for 250.00
Prw 1.6 7/16 stud roller rockers brand new in the box for 200.00
procomp 1.6 7/16 stud roller rockers brand new in the box for 200.00
Comp cams high energy 1.6 7/16 stud roller rockers like new for 150.00
(2) edelbrock victor jr intakes for carb 302 in great condition for 275.00 each
1" phenolic spacer for trickflow street heat used with no bolts for 40.00
1" phenolic spacer for edelbrock rpm 2 intake used with no bolts for 40.00
(2)1" phenolic spacers for edelbrock rpm intakes used with bolts for 50.00 each
1" phenolic spacer for gt40 intake used with no bolts for 40.00
Trick flow R upper and lower intake with a 1/2" spacer for a 351 Windsor for 650.00
Trick flow track heat upper,lower and 1/2" spacer for 302 all for 600.00
Edelbrock performer efi upper and lower intake in good condition for 525.00
(1) Edelbrock performer rpm efi upper and lower intakes in good condition for 600.00 firm
Edelbrock performer rpm 2 efi upper and lower intake brand new in the box for 800.00 firm
Gt40 ported lower intake with a custom sheet metal upper intake and nitrous plate to match all for 850.00
(1) gt-40 explorer uppers for 75.00 each
302 timing cover brand new for 100.00
(2) edelbrock victor jr solid roller springs like new for 75.00 a set
Lunati 602/602 solid roller camshaft with a 108 lobe separation part#51019lun used for 250.00
comp cams 692/673 solid roller camshaft with a 108 lobe separation like new for 250.00
comp cams 576/585 Hyd roller camshaft with a 110 lobe separation like new for 250.00
comp cams 555/570 NX274HR-14 Hyd roller camshaft and lifters both like new for 250.00
reed brand 503 lift hyd flat tappet camshaft in good condition for 100.00
rpc sheet metal valve covers for sbf new in the box for 160.00
rpc crank case evacuation system part# R2050 new for 30.00
sheet metal valve covers for sbf motor used for 80.00
Aluminum powder coated blue valve covers with 347 on them for 100.00
Trick flow valve covers with filler neck like new for 150.00
ford racing tall aluminum valve covers used for 150.00
located in barnwell s.c. 29812 No shipping on large items and shipping and paypal fees will apply on small items
phone number 803-300-0855 (please call or text between 9am and 9pm for faster response)
Discussion Starter · #10 ·
This 1 is ready to go besides I would put a new set of lifters in it,if you want to text for pics that's fine I may have a few already on my phone.
Dss 331 stroker shortblock includes a level 10 block,3.250 nodular iron crank,5.135 I-beam rods,forged flat top pistons,comp custom nitrous camshaft,water pump,main support,windage tray,canton oilpan all for 2,500.00
im going to hang onto the other one that's posted and freshen it for a backup motor
Discussion Starter · #13 ·
10SEC93GT They are pedestal mount,price is firm at 250.00 plus shipping and paypal fees ,if your seriously interested and fine with that price ill be glad to get some pics for yah,just let me know.
Discussion Starter · #17 ·
Pretty sure there were taken off of victor jr heads to put hyd roller springs on and I believe standard was 650 lift
1 - 20 of 33 Posts
