my headlights were working just fine but now they're not after doing a header swap. I have an 89, checked the switch wiring and everything seems fine, my parking lights work, dash lights up, flash to pass works, but no headlights on low or high. I did drop the steering column to remove the steering shaft and ragjoint, reinstall was a pain having to jerk the steering wheel back out so I'm not sure if I pulled off a ground or accidentally unhooked something.... any help is much appreciated
pins not seated
if that is not it, most likely MFS
is this a GT?
yes out of the connectors
