You can reference here:
http://www.accusump.com/index.html
I read up on it, and I pretty much understand how it works, but a couple questions still remain.
For the cold start-up pre-oiling, it doesn't actually locate the crank & rods off the journals, it only starts oil flowing so that when the engine is cranked, there is already oil flowing so the parts can immediately get on the cushion of oil right?
Based on the descriptions, an Electric Valve setup is only used for cold-starts. An EPC is required for protection during braking/corners and any other loss of oil from the pick-up. I assume the E.P.C. setup also offers cold-start protection? I didn't see it spelled out in the info, just want to make sure.
I figured I would throw the tech info in this thread also, anyone wondering can see it all in one place. Prices listed are what's off Canton's site...like anything else, a dealer is cheaper.
For the tech, here's a little diagram I stole.
Normal operating conditions:
Discharging When Pickup Is Uncovered:
I'm also going to assume that I need the standard 3-quart setup? (Turbo 351W)
1 Quart - 12" x 3.25" (#24-046) $150.00
2 Quarts - 12" x 4.25" (#24-026) $167.50
3 Quarts - 16" x 4.25" (#24-006) $177.50
3 Quarts Hi-Pres - 22" x 4.25" (#24-016) $187.50
The Accusump Electric valve
(#24-270, $107.50) Provides convenient hands free operation of the Accusump. By wiring the valve into the ignition switch the Accusump will automatically turn on with your ignition and provide pre-oiling. This is especially useful when the Accusump body is mounted in a hard to reach location.
Electric Pressure Control Valving
E.P.C. Valving (#24-271, 24-273, 24-275)
Our E.P.C. valving has the convenience of an electric valve and the rapid refill rate of a manual valve. The E.P.C. valving allows the Accusump to quickly charge with oil when the engine's oil pressure is above a predetermined level and discharge when the engine's oil pressure drops below that level.
Comes with an electric valve, regulator, toggle switch, wire, terminals, and a pipe nipple.
Part #:'s
24-271 $148.50 E.P.C. valve kit for a discharge of 20-25 PSI
24-273 $148.50 E.P.C. valve kit for a discharge of 35-40 PSI
24-275 $148.50 E.P.C. valve kit for a discharge of 55-60 PSI
Manual Valve
(#24-260, $8.50)
This valve is the simplest and easiest to install of all our Accusump valves. It is ideal when the Accusump is being mounted within reach of the driver.
This manual ball valve has 1/2" N.P.T. fittings.
What E.P.C. Valve Pressure Setting Do I Need?
The Accusump E.P.C Valve is offered at three different pressure settings. Each valve is designed to allow the Accusump to recharge when the engine's pressure is above the pressure setting and to discharge when it is below.
When choosing the pressure setting that is right for your application it is important to consider you engine's oil pressure during normal conditions. You will want to choose an E.P.C valve setting that is below that normal engine pressure. This way when your engine is running normally the valve will allow your Accusump to accumulate oil pressure. Then when you engine drops below its normal pressure and the valve's pressure setting it will discharge its accumulated oil in the Accusump. If unsure of your engine's pressure it is best to choose the E.P.C valve with the lowest rating, the 20-25 psi valve.
They also were nice enough to put togother a parts list of what is needed for a typical SBF installation.
Ford V8 3qt. Accusump kit:
#22-565 Accusump input adapter
#23-245 (two) .5" to -10AN fittings
#23-705 (10ft) of high pressure hose
#23-725 package of two hose ends
#24-006 3qt. Accusump
#24-270 electric valve kit for pre oiling applications "ONLY"
#24-271/24-275 epc valve kit for racing applications
#24-200 mounting clamps
$429.75
My other question is about a turbo after-cooler setup they have. I'm going to guess that the standard accusump, and the turbo after-oiler are two independent systems? The standard accusump can't be used to perform the function of a turbo after-cooler can it?
Thanks very much!
-Dave
Part #:'s
Manual Valve
(#24-260, $8.50)
$429.75
Thanks very much!
-Dave
