1 - 11 of 11 Posts
i know darrin made 370 on his pure street car. I'm just curious if that intake maxes out around that hp
any of you guys with 331s or 347s make more than that?
ROG30Y said:
theres one guy on here that made 390 something with a 331 and this intake ported i just dont remmember his name.
thanks
hows that 347 coming?
engine is running well,just found out i had a fuel pressure problem it would drop from 48 to 30 between 5500 and 5800 so it should make over 400 with no other changes.
dont you have an rpm intake on your car,is it ported or not?
yeah i have an rpm setup on my 351w...it is ported...the lower flowed about 272 cfm after the porting was done.......my heads on the intake side flow 300 cfm though so the intake may be choking it off some
I'm planning a custom cam swap so i'm hoping to see around 370 rwhp and like 400 rwtq :evil:
are you running any kind of powerpipe (4 inch etc...?)
i do run a homemade 4" pipe.have you thougth about taking some runner length out of that intake,its longer than the regular one for the 302 because of the lower.i wouldnt be afraid to take a couiple inches out of it.also i have an rpm at the house that i am working on.there is alot of room to make the runners bigger,the one im porting will almost match a 1262 gasket all the way through when its done.
Why not switch to the tfs 351 intake? Jimmc is over 400rwhp with that.
I'm considering that actually.....the cam i have specced out is designed with my current intake in mind...If i get that intake the cam specs will need to change
it just depends if i can find a good deal on a TFS.......I used to run a TFS actually way back when and it never really made much power with the unported TFS heads and 9:1 compression......now i wish i would have kept it :mad:
I think streetpower331 was the guys name that made 380 or so with the Eddy intake. He did in fact do some work to it. I dont remember if he took 1" off or not but I know he did shorten it.
aaronc on here made 340rwhp with his 306 with the regular performer 5.0 intake. custom hitech cam, AFR165's with 2.02 intake valves
1 - 11 of 11 Posts
