...now the vibe can be more heard than felt due to the damper, but it's not quite right yet...
...this was a couple of years ago, but I tried everything that you did...finally solved it with new t-45...it was the output shaft...been 'vibeless' ever since...
CbrCpe - do you have 3.27 gears, or have you installed lower ratio?
Just a thought, Check tire balance and tire concentricity.
The balance may be right but if the tire is not round anymore you will have a vibration. Z rated tires are bad for this.
My 99 has 27,000 miles on it. I have a lot of vibration. Wasn't there when I bought the car. The tires are worn out.
How about changing shock absorbers to an aftermarket brand.
good luck
