1 - 20 of 21 Posts
i installed some h&r super springs in my 86 t-top car yesterday along with some other pieces. the only issue i have so far is the front sits about an inch higher than the back. any idea fixing this? or anyone else having this problem?
also maybe trying to squeeze this question in. my bilstien strut wouldnt fit because of the older spindle. for me to use my struts i have to switch to a 87-93 gt spindle correct?
The most obvious question is, did you put the right springs front and back ?
Did you use isolators on one or both ends ?
Did you tighten suspension nuts and bolts while car was in the air ?
isolators front and back. yes correct springs were placed in. yes tightened in the air
The back sits like it should and the a arms weren't loosened when we put the springs in. We just took the struts off and loosened everything else up. What part of the arm should I. Loosen and then let the car settle on the spring?
Super Moderator
The bolts that hold the A-arms to the K-member. And make sure the swaybar endlinks aren't hung up on the A-arms.
Are the isolators new or re-used? I know my old ones where squished down quite a bit. Replacing with new ones raised the car up a little.
They are new from upr. Also what do you mean hung on the a arm when you were talking about the endlinks? They were installed the way they came off. The endlinks are new and came with my eibach sway bars that were put on also
I think what MFE is saying is that you need to torque the a-arm bolts and also the end link nuts with the front suspension loaded. If you do it in the air (not loaded), the car may sit higher and ruin your a-arm bushings.
But the OP is saying he did'nt loosen up the A-Arms in the first place, so he's saying "Why do I have to tighten them if they were'nt loosened?"
Maybe that's the problem, they weren't loosened in the first place......
Well when asked if he tightend eveythig back up while in the air the OP said he did. That implies that he loosened stuff.
Be that as it may the stock rubber bushings on both the front and back do not freely rotate in the shells. In fact they are bonded to the shells. In addition, when they torqued to specs the serrated end of the bushing bites into the k-member, arm and/or chassis, as the case may be, preventing any rotation on that end. Thus, the rubber bushing "twists" as the suspension articulates, but "springs back" to the original, static position, which is generally ride height (these bushings also add wheel rate and in the rear can cause snap-oversteer when pushed to bind - i.e., no more twist). Now, if the OP simply took hios stock springs out and put the H&R SS springs in, which results in a 1" or more lower ride height, the a-arm bushings are currently twisted to perhaps max tollerance and are near bind. Hince, the front appears high; it probably rides like crap too. As for the rear, I speculate that the bushings are broken or otherwise able to rotate in their shells making the rear appear normal height.
The suggested solution, loosen all the arms, set to ride height with full weight on the car, retighten the fasteners, is a sound solution, given what we know of this installation.
Kind of shuts the door on that implication
That's what I was saying. The problem is really from the fact that he didn't loosen the A-Arm bolts, and now they are bound up.
Discussion Starter #13
The back of the car sits like should with the lowering springs. Its the front that is sitting higher then what I believe it should. So if I'm reading everything correctly; I need to loosen the a-arms, and endlinks sit it back on the ground then retighten it?
The A-arm bolts weren't loosened on my car when we changed the springs. No problems after. Are the pigtails in the correct location?
Yes, but a little after "we" were led to believe that stuff was loosened. Perhaps we should just assume incomplete answers before trying to help.
Yes you were - and FIRST I might add.
USAF retired
Did you have it at ride height when you tightened the front sway bar? When I first put the SS springs in my car the rear was a little lower as well, but not an inch. I contacted H&R and told them what I wanted, they sent me new rear springs that were a little taller, problem solved.
Discussion Starter #17
David it was tightened when the car wason jackstands and the front was hanging
When I installed the H&R SS Springs on my '01 Cobra, the front dropped into the weeds (stock rubber isos and Bilsteins). It's actually too low; so low the K-member is about 3" off the ground. As a result, the K has hit high spots in the road such as repairs and ridge-peaks; I have to watch for debris and rocks and have to be careful of those manhole covers if they are set high. Really diffficult to see this stuff at speed especially at night. Major PITA, but I still love the look; 10 years on the car now. My point is that the front should not be high.
Discussion Starter #19
just thought id update this.
i loosened the a arms today sat it on the ground and bounced it. the height still remains the same with it an 1in or so high in the front. anymore suggestions?
could it have to do anything with the stock struts?
Are the pigtails aligned right, covering the first hole but not the second? You could pull the isos to lower it some or if you don't want to do that you can use a cutoff wheel and cut about 1/2 a coil off the bottom of the front springs. If you cut them you might want to take less than 1/2 a coil at first as once you cut it off you can't add it back, but if it is 1" higher I don't think 1/2 a coil would be too much.
1 - 20 of 21 Posts
