I am thinking about getting one but im not sure which one
H-Pipe or X-Pipe and also if should get and off-road or hi-flow.
Which is better?? I think i want to go with the hi-flow
because i need emissions, would the hi-flow be worth getting
and with hi-flow cats will you still pass emissions??
Do it give you an increase in power over stock? Also would
it be any louder with the hi-flow??
I have a high flow H-pipe on mine and it was louder than the stock 4 cat pipe. It will be quite a bit quieter than an off road, but will pass emissions. An X-pipe will also be quieter than an H-pipe but should make a little more power!
Good luck.
