Going to the track this Sunday for the first 1/4 time this vehicle has ever seen. It's actually a buddies vehicle, but we'll both be driving it. Here are the spec's
1990 Ranger single cab w/ 302 swap
world heads
main stud girdle
arp head studs
comp cams valvetrain
mild cam
1-5/8" - 3" longtubes
Trick flow lower ( i think, or at least comparable)
box upper
70mm tb
UD pullies
Zex 100 dry nitrous
Viper t-56
built 31 spline 8.8 with 4.56 and mini spool
10.5" hoosiers
leak spring with traction bars
Can't remember brand, but it's got a grippy clutch and lightened chromoly flywheel.
Thanks for the input. I'm decent at shifting but have never driven this truck down the track before. The owner has, however, so he'll most likely run a better time than I will. First time on the new setup. It ran a 9.4 in the 1/8 with a stock t-5, stock motor minus the cobra intakes, and 4.10's with okay tires.
-Thomas
