I'm a little bored at work and my cars almost done. I'd like to see if anyone here has a similar set up and what does it run? If not, let's throw some ideas out there.
1985 Gutted Coupe with manual everything including steering and brakes.
351 Roller Windsor motor with stock Crank, rods and pistons.
Ford Racing F-cam
Trick Flow 11R 205 cc heads
Comp Ultra Gold Roller Rockers
MSD ignition
Victor Jr. Intake
Pro Systems 850 carb
C4 with Manual V/B and 4500 stall converter
Let's hear it.
rear gear? rear tires? rear suspension?
I would be really happy with an 11 second slip but even more ecstatic if it could run an 11.50 for the local index we have.
The car has 3.73's currently. fully built rear with UMI fully adjustable upper and lowers. I need to get some new tires for it. I would have went bigger on the cam but with the stock 351 pistons there's not a lot of room with PTV clearance. As soon as I get this car finished up and going down the track i'm gonna start on a aftermarket block and go stroker with a more appropriate camshaft.
