Hi,
I have a GT500 throttle body, BBR adaptor plate with the matching stainless allen allen bolts. The throttle body was machined by me at work to fit right on with no problems using the BBR plate. A stock GT500 throttle body will not bolt onto a 05-10 mustang intake without machining the mounting holes. I found that out the hard way...The TPS sensor screws were removed and replaced with stainless allen screws so you can adjust the TPS volts...I already did this so it will bolt right onto your car. ***This also comes with the correct size stainless T-bolt intake hose clamp and an OEM engine cover that has been trimed to fit on with the larger throttle body.*** Came out nice and looks good all ogether. I ran this with the JLT cold air intake. I have no idea if it fits with outher intakes. I have over $350 into this entire kit.......I will take $250 shipped to the lower 48 using US priority mail.
If you want PICs....... email me and I will return with attached PICs.
[email protected]
I would prefer Paypal also.
THANKS............ :)
Discussion Starter #2
No takers? Figured here was better than Ebayin it.........
