im trying to get some info of these motor for a possible upcoming project.
how much hp can a gt500 motor hold? whats the weak link in these motors and what kind of rpm can they spin too??
thanks
the GT500 engine can withstand quite a bit of abuse when hit with boost and or nitrous. There are stock block GT500 rolling around putting down well over 1000RWHP. If you want more, the internals can always be upgraded. The block itself is very stout and will hold up to about anything you can throw at it.
haha thanks
ok thats good to know, what is the weak link in them, pistons,rods.... do you know if an e4od tranns would bolt up to it?? how do you think it would handle a 4000 lb vechicle? whats the hp of a stock long block??
thanks
rods are a weakest link! E4OD will not bolt up. You would need to used a 4R70W if you want overdrive automatic. Stock gt500 hp numbers are 500, and they weigh close to 4000# with driver so you can base off that.
Administrator
If you leave the stock rev limits alone then the motor can make tremendous power and still live. Once you start spinning things above that you will need some upgrades to rods to ensure survivability.
To spin them above that without upgrading internals is just asking for trouble.
ok thanks, what type of power could one make with better rods?? and what does it rev to safely??
im not looking to over rev one, just keep it safe but make GOOD power, keeping it SC'd.
whatd you think it would take to bolt on an e4od??
