I imagine it is possible to use my MM Full Length SFCs with the top half of the Griggs frame kit but i just figured i'd ask before i start ordering some more parts.
Does anyone have a set of instructions or even a step by step how-to?
The car is a 1993 Mustang GT.
Also, whats different about the world challenge pieces that allow "taller drivers" more room?
Dimitri
The "through the floor subframe connectors" in the Griggs WC kit sit low and require a section of the floor to be cut out and then they are fitted in and welded. My car already had some old ass saleen subframes which worked just fine with the WC kit. If I were starting bare I would do Griggs upper/lowers but this worked just fine. Sorry, no pics as Griggs did the install.
I already have the MM connectors on the car... just wanted to make sure it was ok. Calling Griggs on tuesday to order their upper frame kit, unless my shop can fab up their own.
Going full MM on the rest of the setup... after 8 years of saying i'll do it... im finally getting off my ass.
