1 - 20 of 25 Posts
Since the last track outing, I learned a few things. Replaced my Bigs Stage 5 950 with a Pro Systems 1000, changed the fuel from 116 to 110. NGK9s to 7s.
1st pass off the trailer (transbrake @ 5100), ~1 tire rotation
60ft: 1.6578
330ft: 4.5789
594ft: 6.5028
1/8: 6.9340
mph: 104.37
1000ft: 8.9679
1/4: 10.6779
mph: 131.56
2nd pass off the footbrake around 2k (dead hook)
60ft: 1.6810
330ft: 4.6029
594ft: 6.5290
1/8: 6.96
mph: 104.19
1000ft: 9.0029
1/4: 10.7280
mph: 130.73
Jetting in the carb was out of the box from Patrick, all I did was set the idle and the floats. If anything, it's a little fat and could be leaned out a jet size or two. I'm happy to have picked up 6.5mph with the carb, fuel and plug change!
I added 2 degrees of timing (from 32 to 34) but it spun off the line and I had to get out of it. Same thing goes for the 100 shot pass I attempted.
I have no doubt there are 2-3 tenths left to shave off, but I wasn't able to get many passes in since it was a race event.
I ordered a fresh set of tires to replace my 10 year old ET Streets and am heading back on the 27th. Hopefully for some nitrous action if I can nail the NA tune down a little more and get the car to hook. I'm hoping I can see a 10.40 @ 132-133 out of it before I spray it. The nitrous converter doesn't seem to be hurting the car as much as I thought, but I still need to get it off the line better.
I'm dying to make a nitrous pass! :evil:
props man! get it lined out on the motor. i think there is more in it.
my 89 has a 4800 converter in it and it has ran a best of [email protected] on 26x11.5 et streets with a 1.589 60'. i didnt think it was too bad for a nitrous motor. i think there is a lil tuning left in it.
i took my prosystems 1000hp out of the box and set the idle and floats and have not touched it since. i have never had any problems.
Don't forget, I'm running a glide with a 1.76 1st gear. I'm never going to get it off the line as hard as a 3 speed car on motor the way it's set up.
If I can get it into the 10.40 range around 132-133, it'll be that much better on the jug.
ahhh i see. didnt think about that. how high you going to turn that thing? if your at 5100 on the brake now how high is it going to go on the bottle?
it looks like its kinda laggin or spinning the in the 1/8th but almost 132 out the back door is gettin it done. get that 60 ft cleaned up alil and i bet you got 10.20 -10.30s easy
Good to see some positive numbers man. Looks like that ntirous stall hurting the 60fts a little. That is easy a 9 sec car! Yea guys I havent had same luck with patricks pro system carb setup. Im gonna call him again and see if he answers! I have slowed down 5 mph in the 1/8th ! Called patrick and left message a week ago no reply yet. Im sure he busy. Sorry not trying to jack the thread.. Once again Black congrats on new times.
Boy that is funny cause I put on one of Patricks carbs and picked up.27 and 5mph in the 1/8. just with a carb swap. Go figure. Good times, work on your 60ft and you will be in the nines easy.
It'll be interesting to see what a fresh set of tires will do. Seems to be suffering in the 60 ft. mph is great.
Glide in a street car?
My grandmother's nova had a glide in it from the factory. It was a street car with A/C.
I love my glide on the street! Since when do you nail it with a high HP car in first gear on the street? I mean in a 3 speed + car. The glide takes a lot of the hit out of it. If you have a good converter it will run. Maybe not take full advantage that you would with a 3 speed, but it will be consistent and easy on parts.
Ian any updates.
Tim
Discussion Starter #18
Yes, I run @ Gimli but have run at Fargo and Brainerd this year.
The only update for any motor action is I added 2 degrees of timing and went 133.5mph with a 10.72 on motor, with the same ####ty mid 1.6 60fts.
I made two nitrous passes on the 100 shot. One 9.94 and one 9.95 @ 142.76 both off the footbrake with really mild launches and mid 1.6 60fts.
I have some major suspension issues to sort out. I'm waiting on some parts from TeamZ to take care of that problem. I'm also changing to a set of 4.10s and adding some Strange adjustable shocks.
Next track day is September 5th for me. I'm hoping to get the traction under control, because the tune certainly is! I added an FJO Wideband/data logger and it really helped figure out wtf the car was doing and when.
1 - 20 of 25 Posts
