1 - 11 of 11 Posts
I'm about to build the rearend in my car and was wondering if a 355 gear will be ok? C4 trans 28" tall tires, stock botom end 302, B&G Kit with a 70mm turbo, TW Heads, Street heat intake, Anderson B-31 cam. I have a 373 in the car now, but it deffinatly needs to come out!
Usually the 3.27s are preached. What are your rpms in the 1/4 as it is now? What is your max rpm? I would say 3.55s would be okay but many preach the 3.27s like I said before. Good luck.
I started with a 3.73, C4, 28" tire. Was OK, but definitely annoying for street driving (no overdrive). Went to a 3.55, made a nice improvement on the street, but ended up breaking the input shaft off the Dynamic C4 twice (on the street!). Dynamic said C4 no like heavy car (3400 w/driver), tight converter (3K), turbo (lots of low end torque), and low rear gear. Ended up going to a TH400 with the 3.55 and went 9.teens at 147. Next swapped in a set of 3.27's and picked up a little ET and MPH, plus made the street driving even nicer. I love the 3.27 in there now, but am tempted to try my stock 3.08 just to see what it does.
go with the 3.27..
did you ever get your converter replaced?
3.08's ... and 26's .
3.27's FTW!!!!
Not to hi-jack, but I wanted to ask a related question. My car has 3.55's and I run 17" M/T Street Radials at the track. My first time out, it didn't really mph where I was hoping it would. Some of it was half of 1st gear (AOD) was with no boost. I need to learn how to launch it better to get it into boost quicker. @ 3500 #'s and 420rwhp it went 90mph (1/8th). Would this be any different with 3.27's? I'm guessing that getting the car into boost quicker would increase mph. Are the 3.55's hurting me?
1 - 11 of 11 Posts
