Hey guys so I am swapping my turbo on my 7.3 Powerstroke and was wondering if I could use it on my mustang. Its a garrett gt 38 turbo with the following specs:
hot side:
.84 A/R
72mm inlet
70 mm outlet
internal wastegate
cold side:
1.00 A/R
67 mm inlet
62mm outlet
Yea that should work. Might be a little on the big side for a bone stock 5.0. But not enough I wouldn't use it. What flange are those?
Also the internal wastegate would be something to address. Those diesel trucks run alot of boost. So you would have to make sure you can lower it.
Sent from my PI86100 using Board Express
Well my mustang used to have a kennel bell sc on it so it setup for a force induction setup and its also far from stock.
