1 - 16 of 16 Posts
I had my car dynoed again at the same dyno and to my surprise my car was up more than 15hp and 20tq, even better was the 40lbs i gained from 3000 to 4000 and the 25-30 hp in the same range. I am very impressed at the numbers to say the least. peak came in at 254hp and 295tq!:joy:
holy ****! are you serious? i just put my pulleys on and, although i felt a difference, i didnt find it to be THAT significant. I dont have a t/a yet, but i want to save up for one....that'll be my next mod probably.
What gas are you running now at 12*?
wow that seems a little high. what kind of dyno was it? i got 6 rwhp and 13 rwtq at 14 degrees but my pullies were already on. ive seen dyno sheets that showed no gains from the pullies. what make were the pullies and timing adjuster.
Nice! That's about 305 at the flywheel! Killer torque! :joy:
here are my two dynos, what do you think?
here is my 00GT with only a pro chamber, 4.10s & K&N,
RPMS: 3000 TO 6100
ABSOLUTE BAROMETRIC PRESS.: 30.07 in Hg.
VAPOR PRESSURE: 0.64 in Hg.
INTAKE AIR TEMP: 91.6 degrees
GEAR RATIO: 56.59 RPM/MPH
CORRECTION FACTOR: 1.00 SAE
RPM POWER TORQUE AIR/FUEL
3000 139 243 13.3
3100 144 245 12.9
3200 152 250 12.7
3300 160 255 12.6
3400 168 260 12.7
3500 174 262 12.8
3600 180 266 12.7
3700 186 265 12.8
3800 193 266 12.8
3900 199 269 12.7
4000 205 269 12.6
4100 211 271 12.6
4200 218 273 12.6
4300 223 272 12.6
4400 226 270 12.6
4500 229 267 12.6
4600 230 263 12.5
4700 233 261 12.4
4800 237 258 12.4
4900 237 254 12.4
5000 239 251 12.3
5100 240 244 12.3
5200 243 238 12.2
5300 241 231 12.2
5400 239 225 12.3
5500 235 218 12.2
5600 233 211 12.2
5700 229 205 12.2
5800 221 198 12.2
now here is todays, the only other thing I can think of is the synthetic oil im running
RPMS: 3200 TO 6100
ABSOLUTE BAROMETRIC PRESS.: 30.24 in Hg.
VAPOR PRESSURE: 0.48 in Hg.
INTAKE AIR TEMP: 91.7 degrees
GEAR RATIO: 55.51 RPM/MPH
CORRECTION FACTOR: 1.02 SAE
3200 171 281 13.8
3300 178 284 14.1
3400 184 285 13.7
3500 191 287 13.2
3600 197 287 13.0
3700 203 289 12.8
3800 210 291 12.7
3900 217 292 12.7
4000 224 294 12.8
4100 230 295 12.8
4200 236 295 12.8
4300 240 293 12.8
4400 242 290 12.7
4500 246 287 12.6
4600 249 284 12.5
4700 251 281 12.5
4800 253 276 12.5
4900 254 272 12.4
5000 254 272 12.4
5100 253 266 12.4
5200 251 254 12.4
5300 250 247 12.4
5400 247 240 12.4
5500 244 233 12.4
5600 243 228 12.3
5700 239 221 12.3
5800 236 214 12.3
I just slapped on some Steeda u/d pullies on my dads 01 GT vert. Holy hell if I wasn't mad as hell at the SOTP gain he got. I got almost no gain putting the MACs on my 98. Should I put the Steedas on?
I may have missed it, but what fuel are you running? I have no dyno number, only track numbers from my pulleys and T/A. My car had run a best of 100.50mph stock with about 4 runs of 40 over 100mph. Most were in the mid to high 99 range.
I installed the pulleys and T/A and the car went 100.50, 100.56, and 100.80 in less ideal conditions than before. This was with the timing at 13 with 93 octane. I was a little dissapointed but figured I picked up a little power. 2 days later I went back and bumped the timing to 15. The car responded with 102.14 and 101.91 runs. Since then I have run pretty much in the 101.50 range. I have moved the timing around several times since I ran the 102.14 and seems there may be a sweet spot somewhere on the adjuster that I am kinda missing right now.
I kinda wonder what you might get bumped up another couple degrees?
There should be little or no difference in power gains with aftermarket pullies they are all the same diameter so there would be no reason for it. The difference is in the quality, durability and the ability to use it with a TA.
Bill
Bill
so Bill are you saying all the gain is from the TA? I know this is not normal, can someone explain how I gained this much?
LX Hatch before I was traping around 99-100 now im at 102-103 ( i have only hit 103 1 time) this was at 12
89FOX, I don't think Mustang92 means that the pullies made no improvement. What he means is that two companies making the same size pulleys will get the same results if you understand how underdrive pulleys work.
Discussion Starter #13
Ahhh yea I misread his post, I do get the underdrive process, and that’s why I asked him to explain, I’m still not sure where the gains came from.
Very nice .. when I had my 98 cobra, pulleys was one of the best bang for the buck mods I did. 10+rwhp and about 14+rwtq peak gain with gains all through the RPM range!
Crowley
Joe had it right I should have clarified that there isn't any real difference between the aftermarket pullies from different companies performance wise.
The gains are from both, I picked up 9.2RWHP from my TA alone. I didn't get exact numbers from the pullies but I'm sure it was comparable.
Bill
THAT BIG DIFFERENT FROM SO LITTLE
i got a 02 gt 5 sp,need to modified. notice you use kn and the steeda pullies.
the kn is just the filter itself not "cold-air-fender-mounted"kit. i was thinking
using the march pullies... i don't think there a different between them?....
i was reading the May 02 mustangs&fastfords...... they compared the old
66' gt350 vs 01' gt. i couldn't believe the time the 01 was pulling. stock car
best time 13.90 to 14.43 in the quarter mile..
1 - 16 of 16 Posts
