I have a dual hat with twin 340 lph pumps. The hat has a 10an supply and and 8an return. I plan to run gas and e85 at some point. The car should make close to 600hp. What fuel filter do you run? And what regulator.
I have the aeromotive filters on my 02 harley truck as well. I have three pumps with intank filters and an aeromotive 8an filter on each line coming out the tank. I modified a stock hat with four 8an lines. When I put my fuel system together the best e85 verified regulator I could find was the deatschwerks dwr2000 which is what I run on my truck as well.
https://www.deatschwerks.com/blog/dwr2000-adjustable-fuel-pressure-regulator
I run a hybrid return/returnless fuel system so my regulator is mounted on the side of my fuel tank and only used as a PPRV (if my frps fails and the pumps go 100% dc) but other than bleeding pressure down after key off I have no complaints about it.
I even have ID2000 (220lb injectors) as well still using the stock ecu and my fueling is perfect and always stays dead consistent even idling at 600rpm on 87 octane pump gas.
