Hey curious what is a good size injector for my 5.0 turbo motor, i cant put any more power than the stock block can handle. also does it matter what kind on mass air i use thanks
get a set of 42's and you will have a bit of room, what do ya mean on the mass air are you going to blow through or suck through it? are you going to have it tunned at a shop and not make anymore mods? can you trailer it to said shop if so then the sct stuff will be great. if not then the pro -m stuff has been out for a while
