1 - 8 of 8 Posts
Currently running a hp150 with a vortech v1 and a qft 850, switching to a turbo setup at 10psi what kind of hp will that Holley 150 support on a blow through setup??
Not much since the pump only supplies 7psi fuel 10# boost you will need at least 16-17# pressure or you will run the fuel bowls dry. when is was blow through I use a magnafuel 500, it would supply 36# pressure.
1 - 8 of 8 Posts
