1 - 20 of 20 Posts
85 Mustang GT
Licensed/Registered in Indiana
Clean title
3in cowl hood
Freshly painted Nissan B16 (350z blue)
Brand new black headliner
Non foglight front bumper
2 small dents on bottom of driver door (pictured)
Rear-end
8.8 preloaded aluminum rear diff cover
33 spline with spool
Welded tubes
3.73 gear
New ebrake cables
C-clip's eliminated
Electrical
Complete 89 wiring and interior swap
FAST Bank to Bank ECU
Ashtray switch panel with fuses under dash
Battery relocated
Flaming River push kill switch next to license plate
New headlights
Suspension
PA Racing K member
PA Racing shorty A-arms
PA Racing upper double adj
PA Racing lower control arms
PA Racing Anti-Roll Bar
All solid bushings
Strange 10 way adjustables
Battleboxes bolted/welded in
Subframe connectors welded in
All rust removed, new floor pan on pass side
Flaming River Manual Steering Rack
Coil Over's in front - 18in 175lb
Eibach Springs rear
Brakes
Brakes plumbed for line lock
Rear drums rebuilt
Front new pad, calipers, rotors
Manual master cylinder
Fuel
Stock tank sumped by C-Line Engineering, -10 fittings
Granatelli Motorsports Pickup Assembly - Return line
Wheels/Tires
Weld Prostars 15x10 in back with 295 tire
Weld Prostars 15x3.5 in front
Pics at http://creceveur.smartboxllc.com/forsale/
nice car man!
Will sell without the Prostars, Aeromotive and FAST system as a roller for $2500
85 Mustang GT
Clean title
3in cowl hood
Prostars and FAST system removed, will have V6 wheels/tires to roll.
New ebrake cables
Suspension
PA Racing K member
All solid bushings
Rearend
Eibach Springs rear
Built 8.8
Tubes welded up
Ford Racing 3.73 ring/pinion
Strange C-clips eliminators
Strange 33 spline axles - 5 lug
Drums freshly rebuilt
Strange Engineering Spool
Alum differential cover with cap support/preload
Tabs welded on for anti-roll
All parts brand new bought. ZERO MILES. Built and rolled around. Car being parted out unfinished.
Brakes
Electrical
Battery relocated
New headlights
Discussion Starter #12
bump
Here's all fuel I have left:
-10 AN 6ft feed line with a 90 hose end fitting
-Sumped stock tank (2 -10 ports) with Granatelli pickup
-10 cap off to feed from sump port and return through Granatelli pickup to avoid turbulence/starvation in sump
$300 takes it
Discussion Starter #20
85 Mustang GT - NO Rust
Clean title
3in cowl hood
No-foglight front bumper
2 small dents on very bottom of driver door (pictured)
No suspension
Interior
Complete 89 gray interior swap *very clean great shape*
New headlights
Includes sumped tank setup below
1 - 20 of 20 Posts
