1 - 9 of 9 Posts
Alright, i'm going crazy cause i can't change out my front turn signal...what do i have to do to get the old one out and change em??? All i saw was the one nut on it and i thought it should just pull out, but it won't, WHAT DO I HAVE TO DO??? I looked at it and 3 other guys at autozone did too but we can't figure out whats holding it in???
HELP ME PLEASE
You just have to pull them out. They have like 3 rubber grommets that hold it in place. Have you ever cange them before? They may be in there really good.
I'm not the original owner, but for all i know they've never been changed. I'll just go out there and give it my all, i thought that they would just pull right off to the side of the car...but i didn't have any luck. Time for round two i guess.
pull straight out, or you might break the tabs.
Alright, so i got it out, and switched the light but it still doesn't work all the time??? HERE'S WHAT HAPPENS: I switch on the right turn signal and it clicks really fast and it doesn't light (in the dash) and the front light doesn't work and the rear turn signal blinks really fast. But it does sometimes work just fine without any problems...is this a wiring problem of some nature or something???
I had the exact same problem. It turned out to be the grey plastic mount. I don't have the p/n but it ran like $5.00.
thanks, i'll check it out.
Alright..new problem... I switched the bulbs and connectors (put the left in the right one and vice versa) well the left still works but the right doesn't...what the heck could this be?????
Note: the right turnsignal works fine if it isn't clicked into the locked position (like just pushing it up to start the signal but not all the way up where it clicks into place so you won't have to hold it) when its all the way up it goes crazy and only the rear works and it signals really fast.
1 - 9 of 9 Posts
