Captain Chaos
Ok, I know I have a bad driver's side strut, however this one has me scratching my head.
I haven't been driving my car much, because I know the strut is out. Well yesterday I had to adjust my clutch cable, and I was driving it around the block to test it, and when I parked my car and got out I notice my driver's side front suspension was fully compressed, the fender was almost sitting on the tire.
So I put the jack back under it, jack it up and after about 15 seconds in the air it slowly decompresses, with a crackling sound. The closest sound I can think of is rust falling on a piece of sheet metal.
Could this be the strut, I don't know, hanging up somehow? Or am I into other issues, ball joint etc?
Captain Chaos
Defective struts can bind and prevent the suspension from returning after jounce. I would put money on the strut being seized.
Thanks. I really didn't want to get into changing out the springs, as I like how my car sits.
I've had a rattle from the front end going over my bumpy local roads, and I've had it in the air and checked everything and nothing's loose, and it doesn't pull, so I had it narrowed down to the strut.
Read your first post wrong, you said the front decompressed with the car in the air, that makes sense that the strut is binding.
Captain Chaos
Ok, another quickie. I have MM Caster/Camber plates. Will changing the strut require me to get an alignment?
I've only ever done straight shocks.
As long as you don't mess with the C/C plate and mark WHERE the strut bolts to the spindle you won't.
