1 - 8 of 8 Posts
I wanted to try a smaller front sway bar and found one and bought it at the salvage yard but the guy couldn't tell me what it came off of. I measured it and it doesn't appear to precisely match up with any of the 96-04 sizes. So now I'm wondering if it could be a Fox body sway bar. I have a 97 cobra.
Most vendors have different parts for Fox or SN95 front sway bars so my question is are Fox and SN95 front sway bars interchangeable?
Thanks for the help
Super Moderator
They are different. The SN95 bars are wider between the links, and they're designed to mount differently to the frame rails.
Fox bars mount on brackets inside of the frame rails. 94+(I'm going to assume up to 2004) mounts directly under the frail rails.
Jess
Ok thanks for the response. They prompted me to pull the one off my car and compare and its definitely a fox body bar the salvage yard gave me. Saved me from buying the wrong bushings.
I got one for a v6. Had to pull it off at salvage yard. If I get bushings yet in trouble this weekend wmfateam
1 - 8 of 8 Posts
