1 - 9 of 9 Posts
Hey all,
On my ddmi twin kit, i have 2 t-25's. Im having quite a time with these puppies holding oil in the system. They dont like the 60+psi oil they see. Is there some sort of inline restrictor i can use? My first oiling set up was with the INCON oil sender w/ 2 -4an's goin to each turbo(way too much oil). Now ive got one -4 T'd into two -4's(cutting oil in half right?), still too much!
What can i do? Some sort of fitting? I really dont want to get more lines(steel braided, teflon inner) made, theyre quite pricey.
Dom
do you still have the incon parts?
Guy
Fit a restrictor on the inlet oil feed line. Ball bearing T3 Garrett take 1mm restrictors..If not used the seals leak..
SHAAWEEET
WHERE CAN I GET 'EM?
NOW THATS WHAT IM TALKIN ABOUT!! :)
I presume that you have an incon kit? Thanks so much!!
YOU TALKIN TO ME? IF SO, I CAN PROLLY GET 1BAR OUTA THEM(1 BAR = 14.7 YES?)
1 - 9 of 9 Posts
