1 - 1 of 1 Posts
Is there an off the shelf Mustang style bumpsteer kit that bolts on and works with a Pinto rack? Or do I have to buy a tie rod end kit for a chassis car and fab it all up myself...?
All of my front suspension is from PA Racing. K-member, arms and spindles. (I have an email in to Jason at PA as well).
From what I can tell I should be able to buy a typical Flaming River Pinto Rack and the short Racecraft bump steer kit and it should all bolt right up without cutting the tie rods any shorter on the rack. https://www.racecraft.com/index.php?main_page=product_info&cPath=92_539_541&products_id=165
Sound correct? For some reason I'm under the impression I'll have to cut the threads off the tie rods on the rack and use a weld on bump steer kit like you'd use on a chassis car...
1 - 1 of 1 Posts
