Started work on this project with the Automotive Technology Students at school. I started the group this year so we could have something fun around and plan on racing it when it's together.( I am the Sophomore instructor at North Iowa Area Community College)
We have a stock bottom 5.3 LM7 using all ARP Fasteners donated to the club. The best bolts out there and a top notch company to work with. Manley has sent over some pushrods even! We will be using a BRP Hotrods Mount kit to bolt the LS in place. They have some amazing products for all kinds of LS swaps and more. Check them out. Edlebrock has donated a Victor Jr Intake manifold and fuel rails also.
To build the hotside turbo kit we have had Squeeze Performance help us with some flex joints, flanges and V-bands. Painless Performance has donated a very nice wiring harness that will meet up to our OEM GM PCM. We just had a EFI LIVE V2 Flash scan unit with credits donated by Donna Blackmore at EFI LIVE. I have been very partial to HP Tuners, but with the help from EFI Live and there amazing forum, I have become a huge fan. Living here in Iowa, there is a ton of Diesel stuff around here so I think it will be used more than I think!
We are running a 76mm Turbo and a built 4l60e transmission. Still looking for some donations for injectors, radiator and suspension components. Maybe some of the shops, vendors or manufacturer's on here want to help the College Auto Club out????!!!!!
We finally got our dyno installed too. I have been training a couple select students some tuning fundamentals and they have so much fun on it. If anyone needs Dyno time and live's close to the we can rent it out by the hour and day depending on schedule time. The school will only rent the dyno, not tune.
Screen Shot 2014-08-04 at 10.03.43 PM by Wood_Pusher_, on Flickr
10665337_10205037160351463_3194572014321261106_n by Wood_Pusher_, on Flickr
10592750_10205037161471491_2553648928807719375_n by Wood_Pusher_, on Flickr
10458859_10205037158991429_8944235678852192232_n by Wood_Pusher_, on Flickr
10380328_10205037158271411_3274866905209719793_n by Wood_Pusher_, on Flickr
10712901_10205120132705720_915544615705308157_n by Wood_Pusher_, on Flickr
10676129_10205097308575131_1298108807012659863_n by Wood_Pusher_, on Flickr
1453276_10205099865519053_200805706995826761_n by Wood_Pusher_, on Flickr
Discussion Starter #2
Busy week here at school. We got the engine back out from the test fitment and torn down to a short block. The engine is going to a machine shop locally where a couple students will be building it with the machinist's.
American Muscle sent over a very nice banner, some decals and some shirts for the club member's! They love stuff like this!
10734011_10205200440353361_2197595825934304605_n by Wood_Pusher_, on Flickr
10711090_10205200440393362_2533239576573370209_n by Wood_Pusher_, on Flickr
10703636_10205200440313360_1818861152576840878_n by Wood_Pusher_, on Flickr
nice build!
Couple updates! Engine ready to go together. Pleased to say we will be using a Brian Tooley Racing Camshaft kit! This should yield us some great power and give us a pretty nasty sound!
We got our transmission finished and all painted up. After the camshaft shows up the engine goes back in and we start building our hotside of the turbo kit with our parts from SqueezePerformance.com.
1011233_10205247004557437_5967528807888778875_n by Wood_Pusher_, on Flickr
1926690_10205247004477435_1724659598950169816_n by Wood_Pusher_, on Flickr
1480740_10205247004597438_8468090086899251117_n by Wood_Pusher_, on Flickr
10294478_10205247004517436_3225427466493651296_n by Wood_Pusher_, on Flickr
10418853_10205247005357457_7702138306014151668_n by Wood_Pusher_, on Flickr
Switching to a newer style Mustang gas tank so we can run dual 340lph pumps in tank.
10257789_10205247005317456_1293156632795264801_n by Wood_Pusher_, on Flickr
Our local O'reilly's donated some essentials for the build.
1382126_10205247005397458_2797316465386708249_n by Wood_Pusher_, on Flickr
Got our camshaft installed. Brian Tooley Racing custom grind camshaft with BTR Pushrods, Dual Valve springs, seats, seals, retainers, locks and shims!!!! This thing is going to breath well and sound amazing. Used our ARP head studs and bolted the heads down. Very pleased to say we are using an Edelbrock Victor Jr. Intake manifold along with a set of Edelbrock Billet Fuel rails and an Edelbrock Intake Elbow. Should flow very well when all together!
Our Painless Performance Wiring harness came in last week too. I am very excited to use this over other harnesses I have used. This thing is truly a nice piece. The quality of work here is the best I have seen yet. I can't wait to get it on the engine and show finished pics with it all wrapped up and looking sharp! The students literally laid it out on the engine and found every spot it needed to be connected in less than five minutes, very easy to get on. Now we just need to get it routed around the car and get it started up! Top notch place to get harnesses if you want quality.
10636274_10205334630228024_4027913939545612216_n by Wood_Pusher_, on Flickr
1457576_10205288688559511_6259390068622593459_n by Wood_Pusher_, on Flickr
10624727_10205373852848565_440655459943308726_n by Wood_Pusher_, on Flickr
10268538_10205381245393374_6717134644867453052_n by Wood_Pusher_, on Flickr
Just a quick couple pictures here of another truck we are LS swapping in our spare time. This one is our Division Chairs truck. Its a 1937 International Series D. He wanted a nice driver, but nice old OEM look outside. So, I out our foam LS engine and the gutted 4l60 and the students stuck it in place. With zero modification minus a new transmission cross member the engine fits. Stock manifolds will fit between the rails even! The stock floor pan clears the trans with zero modification too.
This truck also got a 8.8 Ford Differential swap and a nice set of Model A disc conversion brakes on the front. We had to mill the original "I" beam down and bore it a little to, luckily our Tool & Die Dept was able to make it all fit together fine. This thing is gonna rock when its all done!
10410270_10205374100934767_1196721464374686180_n by Wood_Pusher_, on Flickr
10421115_10205374100854765_581177437263241035_n by Wood_Pusher_, on Flickr
10628136_10205374100894766_3677070807152026098_n by Wood_Pusher_, on Flickr
Just about to start back up here at school, figured I would start the new semester with a little update. We got the hotside piping all done, intake elbow and TB on, and wiring harness finished. The harness from PAINLESS WIRING was awesome! Went on great and fitment is the best I have ever had with an aftermarket harness. The exhaust flanges and flew joints from Squeezeperformance.com worked amazing too. We also boxed and bared the front frame.
Getting very close to finishing this and getting to drive it! The students are itching away to fire it up and tune it. Still needing an intercooler and some fuel components but should be ready to run soon!
10906074_10205716637977979_2751212335505319385_n by Wood_Pusher_, on Flickr
This build is really cool; even more so that it's with your students! I wish I had taken that class @ college!! Any updates?
