Getting ready to start with the single setup on my Fox. Looking at the best placement for a single 76. Drivers side, passenger side? low mount between rad and engine (if it will fit there)??
I/C is a single inlet on one side, single outlet on other side. so the charge pipe HAS to cross from side to side of the car. Whats better? I didnt know if mounting the turbo closer to the center would help with the exhaust from each bank equalizing exhaust pressure, or if that is even a concern.
...all of them. I asked here, theturboforums, and yellowbullet... for a street car all seems to answer the same.. passenger side is easiest.
same here. yes passenger side is the easiest and thats where mine is located now. just wondering if there is a performance benefit of having equal length hot side
Put the rest of the underhood acces on tonight so I can start fitting the turbo.. its gonna be tight with all the piping under a stock hood.
