Gentlemen and women car in question is 91 notch v8.
I am at a loss. I had the car for 10yrs, 5yrs ago it went to paint.... and longstory just showed back up with a myraid of issues. 1 being blinkers are not working.
Sofar what i have done... replaced both relays 1 in fuse panel other pass side of radio (blinker). Verified 12v at both. Followed up to the hazard switch verified orange wire wht trace and blue wire. Followed over to column... i just found a diagram of the column plugs so i will try to jump a 12v feed in there (as i have 2 blinker multifunction switches that are tested and working. Check harness grounds in front and back. when switch is on (left or right) i get a faint solid dashboard light (btw hazards work fine).... i am only getting 6v at the plug (i cleaned them aswell) no matter which switch i try, 6v no higher no less at every corner
thanks
jim
the flasher is the FIRST thing after the fuse
you have to check the rest of the circuit
it goes through the hazard switch>>multifunction switch>>lamps
if you got 6v volts at the lamps
you have a problem between the flasher and lamps
