1 - 20 of 21 Posts
92 Mustang, Dart 347, twin turbo, fast fuel management, 240 amp 3G alternator.
The car blew a 200 amp mega fuse in the 4 ga wire from alternator to the battery. I replaced the fuse and now it charges intermittently and the alternator gets quite hot. I have tried running a jumper sense wire to tell the alternator to turn on.
I would assume the alternator is cooked. Anyone have any ideas?
why did the fuse blow?
I can only take a wild guess and say it had something to do with the alternator getting hot lol. I gave no clue other then the system had a 240amp alternator with a 200amp fuse.
Just curious, but why are you running such a high amp alternator? Do you still have all the accessories on the motor? Radio/amp system?
It was on the car when I bought it. The car does run a electric water pump, electric fan and electric fan for the tranny cooler. I figure it's better safe then sorry.
the fuse should be sized to protect the current carrying conductor
it has nothing to do with the alt.
so what size is the conductor?
How do I out that? If you mean conductor being the wire; then it's 4ga. If the conductor is in the alternator then I have no idea since I haven't had the alternator apart. It has worked find until recently.
Current carrying conductor that carries current from the alt to the battery
4awg?
have the alternator tested
If you blew that size fuse
I would really try to find the short
That is not safe
If you want to have the alt tested take it to someone with a scope to see the size and consistency of the ripple
you can full field it in situ
if it does not load up, its done
if it does, look to volt reg,,,,,
a scope is a much better diag tool, you can see if you have a faulty rectifier
like said above, a better test may show more as to what is going on or what has happened. my gut feeling is that something internal has shorted and cleared, shorted just long enough to cause a high current spike to blow the fuse......now the alternator is toast. look for an alternator rebuild shop, as well as testing it, they may be able to find what component or components failed, it may be repairable.
With an alternator that big you should run no smaller than a 2awg. It actually should have a 0. Make sure your power and ground cables are matched in size. Something else to consider also, it's absolutely pointless to have lets say, 0 gauge cable and then terminate it with lugs that are too small to fit. Once you begin to trim away strands to make the lug fit, you just took away that cables ability to carry that load safely. It will almost certainly overheat. Also, what pulley size is on the alternator? Under drives are good but in your case, with that much demand, I would make sure I was running the stock pulley.
Poster can use any size wire as long as it fused protected
But you right, that alt is capable of large current
Sure you can use whatever you want, but from my experience, which melted pretty much everything under my hood, you definitely want a cable matched to the maximum current output. Damn Indy... I hope that was sarcasm... Lol!!!
you can have a 200 amp alt
have 100 amp worth of load in the car
and have wire rated at 125amps, with a 125 amp fuse,,,,,,and run for the rest of enternity
  • Like
Reactions: nastynotch91
true^^^^. If the regulator is functioning correctly, the alternator only puts out as much as needed. The amp rating is what the alternator is capable of, not what it is producing at all times.
Discussion Starter #20
OK, so I went and replaced the alternator with the stock 3G 130 amp alternator and replace the 200 amp fuse. I know the fuse is too big for this alternator but just for now I tried it. The alternator puts a 14.4 V at idle, but slowly makes its way down to 13 V by the time all the fans kick on and the alternator gets hot fairly quickly. I took the car for a drive and it runs like crap. I'm guessing that once the voltage goes down then the fuel management and the ignition isnt it running properly.
1 - 20 of 21 Posts
