1 - 20 of 26 Posts
I need to replace the UCA's in my stang and noticed that the Ford Racing M-5500-A UCA's are no longer available. Maximum Motorsports sells a substitute, but they are $200... which frankly I think is a little ridiculous for what are basically stock replacement upper control arms.
The car is a daily driver so I was wanting to use UCA's with rubber bushings rather than polyurethane which I've heard can cause weird handling. Does anyone sell just the rubber bushings separately? If I can't find replacement bushings it seems my only other option would be trying to find a used set of UCA's in good shape, kind of a challenge since the newest SN95 is now 7 years old...
Check out Rockauto.com for bushings. I recall seeing some listed there when I was researching bushings for my UCAs. I ended up finding a new M-5500 set on eBay a few months back.
I actually looked and did not see any at all, but I will try under a different year/model. If anyone has a part number for bushings that might be really helpful!
Summit is showing they are no longer available.
Luckily I bought a set a few months ago.
There must be some vendor out there who has some left in their inventory.
I should have bought a set a couple years ago when they were still $65. Pretty sucky that Ford stopped making these, there is still a market for them...
Ford Mustang Rear Upper Control Arms, solid axle, 1979-04 [M-5500] : Maximum Motorsports, the Latemodel Mustang Performance Suspension Leader!
Actual product may differ from photo.
$199.97
Part # M-5500
Manufacturer: Ford
Pair of direct replacement rear upper control arms for 1979-04 solid-axle equipped Mustang. Identical to the no-longer-available M-5500-A Ford Racing Performance Parts (FRPP) control arms.
This Item fits:
7.5" and 8.8" Mustang rear axle housings
Benefits
Restores performance lost due to old, deteriorating bushings.
Rubber bushings are higher durometer (stiffer) than original Fox chassis upper control arms, for improved axle control.
Rubber bushings accommodate the motion of the Mustang 4-link geometry, allowing suspension movement with less binding than urethane upper arm bushings.
Compatible with a Panhard Bar
Product Features
Rubber bushings are pre-installed at the chassis end
Identical to the obsolete FRPP M-5500-A control arms
Notes
**** Does not include axle-end bushings!
Axle-end rubber bushings and installation tool (MMT-1) are available separately.
Rubber bushings require that the pivot bolts be tightened with the suspension loaded, as at normal ride height.
This Item includes:
Pair of upper control arms
Also, if needed, for the differential-side...
Mustang Rear Upper Control Arm Bushings, Differential Side, pair [E4SZ-5A] : Maximum Motorsports, the Latemodel Mustang Performance Suspension Leader!
$34.95
Part # E4SZ-5A
Manufacturer: Ford
Fits 7.5" and 8.8" solid rear axle Mustangs from 1979 through 2004.
Replace differential side (aft) upper control arm bushings when installing new rear upper control arms on your solid axle equipped Mustang.
Two bushings are included to replace the aft bushings in the axle/differential housing for each upper arm.
The bushings are pressed into Mustang 7.5" and 8.8" axle housings using our special tool.
The chassis side (forward) upper control arm bushings are integral with the arm.
Never replace rear upper control arm bushings with urethane, due to induced binding, and resulting chassis damage.
Upper control arms must rotate and pivot with axle motion, and rubber is the only material that sufficiently allows for this twisting without chassis damage.
Rear Upper Control Arm Bushing Tool [MMT-1] : Maximum Motorsports, the Latemodel Mustang Performance Suspension Leader!
$29.95
Part # MMT-1
Manufacturer: Maximum Motorsports
Rear Upper Control Arm Bushing Tool makes it much easier to change the rear control arm bushings at the differential.
The bushings are a press fit in the differential housing, and are difficult to access when not removing the rear axle assembly from the car.
Unique MM tool makes this tough job much easier and faster.
Presses the old bushings out.
Presses the new bushings in to the correct depth.
Works on both 8.8" and 7.5" axle housings.
Only for 1979-04 Mustang with solid-axle.
Not for 2005+.
Yeah, I don't really want to spend $200 on stock UCA's though.
I replaced the axle end bushings already (building an entire new rear end at the moment).
I think I found some replacement bushings for the UCA's on rockauto, unfortunately I think they are the older style softer bushings, but oh well. $16 for new bushings vs. $200 for new arms, I guess I can live with it.
I bought the MM uppers, they come come with a nice galvanized coating on them but i put on a nice coat of paint anyway, and they feel a little heavier than the stock rusty uppers and come with the stiffer bushing, worth the price too me, gave up drinking for two weekends straight, boom 200 bucks in my pocket.:barf:
StangPlus2Birds, there is no "OR" involved. If the bushings in the control arms (not diff) are shot, those need to be replaced. Unless you're saying that the bushings in the control arms are the same as the ones in the diff.
Steeda Heavy Duty Upper Rear Control Arms - 79-04
Here are the ones I bought. They are reinforced,have the upgraded rubber bushings on one end and come with the energy suspension bushings for the other. I know nothing of this site just posted this link so you could see them. Looks like steda has stopped selling these also but you could probably find someone that still stocks them. If you can find a pair it is the best deal for this type. I paid $89 shipped from a corral sponsor.
The Lurker
X2 on these. Got mine a couple of years ago Late Model Resto. If you check on the side, you can see that they are actually Ford arms that Steeda upgraded with the reinforcement plate. Combine these with the factory rubber bushing on the rear end side, got better than new/stock factory style uppers.
Opps, didn't notice that the bushings were for the differential side.
Thanks for the heads up! Especially since I decided that I'm going to order a set. :) For my '86, I know that mine aren't in the best shape. So, something else to do during the winter Stang rest. :)
Thanks!
Nice, I may be a confirmed MM leg humper, but I like those better. :)
Item# 555-4094
$99.95
Product Description
Back by Popular demand!!! Steeda’s “tried and true” Heavy Duty upper control arms for 79-04 Mustangs are Back! Probably the best bang-for-the-buck suspension component you can put on your Mustang, period.
This OEM Style arm is reinforced to prevent flexing and features a stiffer bushing on the chassis side than factory. Urethane bushings are also included for the axle end. Arms are Zinc plated and come with installation instructions and grease.
Product Benefits
Better handling, more stable cornering Eliminates side to slide "sloppiness" in the rear end Won't damage upper "torque boxes" like other arms Maintains good ride quality.
If you have a stock quadrabind suspension, the control arms are actually designed to flex. If you box the arms or use arms that don't flex, you are transferring additional flexure to your bushings, and through those to your chassis mounts. Unless you've reinforced the chassis mount, you will experience fatigued sheet metal, and possible failure.
Is that site legit? I can't find them anywhere else online. They don't quote shipping cost at checkout either.
The FMS ones are just stock SN95 arms. Get some free stock SN95 arms from someone who upgraded, then just replace the bushings.
I have no idea if that site is legit or not...never heard of them before. I just posted that link to show control arms. I would try steed or jegs or summit and ask if they still have any in stock. Some places may still have a pair laying around even if they no longer advertise them.
1 - 20 of 26 Posts
