Have a set of the infamous "MPH" 2V blower cams for sale, $325. Used approx. 4000 miles engine always had syn. oil.
Can include full set of newer stock 2V roller cam followers too for $375 for cams & followers, followers have maybe 600 miles. Have gone to more boost, bigger cams and more rpm's on 2018 build.
Note: these cams will provide sufficient Piston to Valve clearance w/o notched pistons if installed correctly (degreed in). This cam grind has produced over 600 RWHP with stk plastic intake, 75mm t/b and Novi 2000 at 22/25 lbs of boost in a manual car. Cams be used with a good stk type valve spring too at lower boost/rpm levels.
Have cam spec's (cam card) to provide to buyer only! Don't ask for cam specs, I won't publish the numbers.
Mph blower cams specs that I’ve seen several of for those who are curious.
Specs @ .050
236/236 115 ICL (intake centerline) 115 LSA (Lobe Separation)
