For Sale: super clean garage kept 1990 Mustang LX 347ci. stroker with built C6 that’s a turnkey street legal 9 sec car. The complete drive train is basically new; it has less than 800 miles on it since the build. The car is an original 5.0L/5spd car. Has a beautiful new paint job sprayed with the 03/04 Cobra screaming yellow color. Also had it wet sanded and flow coated as well with an additional 2 coats of clear (4 total). It has black interior in great shape with new racing seats and recently new carpet. It has new tires all the way around, like new wheels and a TON of new or like new performance parts that you can see below. I've owned this car for nearly a decade and have invested over 40K in it, asking $16,900 obo
ENGINE MODS:
Complete 347 engine build
10.5:1 compression
SRP forged flat top pistons w/4.030 bore
Sealed Power File-Fit plasma-moly piston rings for boost set up
Eagle forged 4340 crank w/ 3.40in stroke
Eagle forged 5140 I-beam 5.40in connecting rods
Clevite bearings
World products 200cc cylinder heads that have been extensively ported, polished and have larger intake valves (Intake: 2.08in/ Exhaust: 1.60in)
Anderson Ford Motorsports N91 camshaft (2800-6900rpm)
TFS chrome moly pushrods
Crane hydraulic lifters
FRPP Double Roller timing chain
SLP high volume oil pump
7qt Oil pan
Scorpion 1.6 roller rockers
Edlebrock Super Vic intake
Polished Ford racing tall valve covers
Holley 750 4 barrel carb custom built by Eric Mathis carbs
Dual Holley adj fuel pressure regulators w/ gauge
Aeromotive dual inlet fuel rails to carb
Braided stainless fuel lines from tank to fuel rails
Phenolic Plenum spacer
Full MSD ignition system (w/ billet distributer, 6Al-2 programmable box, coil and plug wires)
Aeromotive fuel pump
Underdrive pulleys
Griffin aluminum radiator
3G 150 amp alternator upgrade
Dual electric 2 speed fan
POWER ADDER:
New never used NOS Big shot wet nitrous system w/ 175-400hp
EXHAUST:
Flowtech polished stainless steel headers
Custom built X-pipe with cut outs for the track
Flowmaster 40 series cat-back exhaust w/ 3" stainless steel tips
TRANS:
C6 built auto trans with new clutches, servos, bearings and etc
Manual valve body
TCI FLEX PLATE W/ARP bolts
B&M Pro stick ratchet shifter
B&M finned and deep aluminum trans pan
Derale Atomic-Cool Remote Fan-Mounted trans Oil Cooler
TCI 3500rpm stall converter
Steeda driveshaft loop
Strange Engineering chromoly super duty 31 spine yoke
SUSPENSION:
UPR adj billet caster/camber plates w/ spherical bushings
Eibach Drag-Launch Spring kit
Lakewood 70/30 drag strut and shock kit
Maximum motorsports weight jacker adj lower control arms
UPR pro series double adj upper control arms with heim joints
Spherical bushing upgrade for rear end housing upper control arm mounts
REAR END:
8.8 Ford racing Performance 4.10 gear kit with new bearings, seals and etc
Strange Engineering 35 spline pro race 1550 steel axles
Strange Engineering 35 spline pro race forged chromoly steel spool
Strange Engineering billet aluminum C-clip eliminator kit with new bearings and seals
Ford racing aluminum drive shaft and U-joints
FRAME:
Team Z subframe connectors
UPR K-member
BMR heavy duty Upper & Lower Torque Box Reinforcement kit
Team Z motorsports launch/anti-roll bar kit w/ heim joint links
BODY:
3” cowl induction hood
Saleen rear spoiler
New Axalta 2 stage paint job w/ extra 2 coats of clear
New clear headlights and tinted/cleared taillights
WHEELS/TIRES
Tires are basically brand new and w/ less than 500 miles on them
Front: 3.5” weld racing w/ new 165r50 radials
Rear: 8.5” weld racing w/ new 275r60 Nitto drag radials
BRAKES:
New calipers and pads
Stop tech slotted/vented rotors
Stainless steel braided brake lines
System just flushed with new fluid
Interior:
4 point roll cage
Black carpet
Black vinyl and plastics
Monster tach w/ shift light
2 new black NRG front racing seats
5 point harness
Rear seat delete kit
Battery relocation kit to rear of car
Billet aluminum dual NOS bottle bracket w/ 2 bottles mounted in rear of car
For Sale: super clean garage kept 1990 Mustang LX 347ci. stroker with built C6 that’s a turnkey street legal 9 sec car. The complete drive train is basically new; it has less than 800 miles on it since the build. The car is an original 5.0L/5spd car. Has a beautiful new paint job sprayed with the 03/04 Cobra screaming yellow color (ford code D6). Paid to have it flow coated as well with an additional 2 coats of clear (4 total). It has black interior in great shape with new racing seats and recently new carpet. It has new tires all the way around, like new wheels and a TON of new or like new performance parts that you can see below. I've owned this car for nearly a decade and have invested over 40K in it, asking 18K obo View attachment 1053355 View attachment 1053356 View attachment 1053358 View attachment 1053359 View attachment 1053360
ENGINE MODS:
10.5:1 compression
Clevite bearings
7qt Oil pan
Underdrive pulleys
POWER ADDER:
EXHAUST:
MAC ceramic coated 1 7/8” headers
Walker stainless H-pipe
TRANS:
Manual valve body
SUSPENSION:
REAR END:
FRAME:
UPR K-member
BODY:
Saleen rear spoiler
WHEELS/TIRES
BRAKES:
Interior:
4 point roll cage
Black carpet
5 point harness
Factory block?
