Cam I.D. is SC-1873-HR15 +4 Can Ed or someone give me the firing order for this camshaft. It's for a supercharged 393c.i. to 440c.i.
normally it's on the card? All of mine are (FTI). Worst case, install the cam and watch your lifters, or if you have the heads on, you can watch the valves and ascertain which order it is. I'm with Woody on this-I would be willing to bet it's 1-3-7-2-6-5-4-8.
I don't know...maybe...email them (looks like they don't take calls)?? Contact
Or hang tight. Ed will probably pop up in this thread at some point. I also agree. I would be shocked if it wasn't the 351W/HO firing order.
You will know if it is the 15426378 firing order if you have the plug wires at 13726548 because it will only run on 4 cylinders. Those would be 1,2,6 and 8.
